It is currently Mon Aug 18, 2025 8:16 am
PostPosted: Fri Mar 26, 2010 7:09 am
First name: Chuck
Last Name: Hutchison
City: Houston
I have a Performax 10-20 and a Delta 18-36. Where would you guys and gals recommend buying grit for the drum?
Thank you in advance.
Hutch
PostPosted: Fri Mar 26, 2010 8:27 am
Hi Hutch,
I used Klingspor when I had a drum sander.
They sell it precut,pre-marked and bulk..They are a great supplier of all things related to sandpaper.
Regards,
Brad
PostPosted: Fri Mar 26, 2010 8:31 am
First name: Chuck
City: Houston
Hey Brad,
Thanks for the tip, I'll go check them out now.
So, you don't use a drum sander anymore? You hand planing now, what's your secret?
Hutch
PostPosted: Fri Mar 26, 2010 9:09 am
I recently bought a bunch from woodworker's supply. They had a special on it and with the contractor's discount it was very reasonable. I got about 3 rolls of 80 grit and 3 rolls of 120 grit for a steel city 26 inch dual drum sander and if I remember correctly it was under 50 bucks including shipping.
PostPosted: Fri Mar 26, 2010 11:50 am
I get 3" rolls from Klingspor as well, inexpensive and good quality, and cut to length for the 10/20 as needed. They also sell the conveyor belts for the 10/20.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Mar 26, 2010 12:15 pm
I got some from Grizzly once that was surprisingly good. I was out of paper and they are right down the street. All they had in stock was the kind that's backed for hook and loop. I was worried that, with the extra padding, it wouldn't sand flat. It sanded fine and I came to believe that it actually helped dissipate heat and made the paper last longer.
http://www.chassonguitars.com
PostPosted: Fri Mar 26, 2010 12:25 pm
Kent, I too use furry-backed hook and loop type paper on my sander, and I also think the "cushioning effect" is helpful. I buy large rolls of 6" Klingspor paper, and cut them up as needed. I wish I could remember where I bought it...
PostPosted: Fri Mar 26, 2010 12:37 pm
I bought mine here:
http://www.supergrit.com/products/produ ... -cloth.asp
PostPosted: Fri Mar 26, 2010 1:06 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Try www.industrialabrasives.com
Mc
Mike Collins
PostPosted: Fri Mar 26, 2010 2:38 pm
Last Name: Abercrombie
What Mike said:
Another vote for industrialabrasives here....
Good service via USPS to Canada, too.
PostPosted: Sat Mar 27, 2010 9:56 am
I buy 50 yard rolls of the 2" Klingspor at Canadian Woodworker for less than $50 a roll for my 18-36.
PostPosted: Sat Mar 27, 2010 1:18 pm
Another vote for Industrial Abrasives, their premarked rolls for the Delta are good value.
David White, Toronto
Users browsing this forum: zmp2 and 20 guests
